Hi all,
I have encountered the following problem:
I have a project in S7 in which the card CP343-1 v2.2 is.
The problem is that I do not have such a card in the HW catalogue and HW update did not help me.
I have the same S7 version as in the computer on which the project was created. I was advised from Siemens that I should do an additional installation of HF5 but they did not tell me where I could get the HF5 from.
The fact that the colleague who made the program doesn't have HF5 but does have this card in the HW catalogue remains a secret.
Another issue is that he is not aware at all of the way how it appeared there.
Could you please help me to solve this issue?
I am using S7 v5.4 SP5.
[?]: CP 343-1 v2.2 and S7 v5.4 SP5
JanRigo
Info
- Faq & Info
Re: [?]: CP 343-1 v2.2 and S7 v5.4 SP5
http://support.automation.siemens.com/D ... n/50583694
SIMATIC NET CP 343-1 Firmware Update V2.4 (6GK7343-1EX30-0XE0)
http://support.automation.siemens.com/D ... n/23183356
or use CP 343-1 from S7 v5.4 SP5 - without "improvements and added functions V2.*"
Update your HWConfig - Hardware Support Packages 2011-07-20Update V2.4 of the CP 343-1 (order no. 6GK7343-1EX30-0XE0) provides product improvements and added functions.
To be able to use the PNIO added functions you require Step7 V5.5 plus Hardware Support Package HSP 1079.
The firmware is available for free downloading on the Internet (see entry ID http://support.automation.siemens.com/D ... n/50583479)
JanRigo
i have it .....
1. download HW update and save (C:HWUpdates )
2. edit hspcontents.xml and change tag "STEP7VERSION"
3. save and install this HWUpdates
Update
- Forum Community
FYI
Hotfix 8 (K5.4.5.
for STEP 7 V5.4 SP5
ftp://audsupport:quoo4Ueg@ftp.sbs.de/s7 ... _05_08.zip
Siemens was wrong about the number of HF as I know. Try it.
BR
Hotfix 8 (K5.4.5.
BR
