connect WinCC flex and 313C with PC adapter
Etherlord
Post by Etherlord »
setup WinCC flex 2008.
I want connect winCC and PLC.
I execute this step.
1. create new project and check "integrate an S7 project"
2. set interface
3. next and finish.
4. enter in step 7 and push "compile and downlods"
5. I have report
Spoiler
Date: 08/11/2011 time: 11:20:40 AM
Compile:
m2_313C\Device_1(1)\Configuration
-> Object was compiled without errors
Date: 08/11/2011 time: 11:20:42 AM
Compile:
m2_313C\master 317\Hardware
Date: 08/11/2011 time: 11:20:45 AM
Compile:
m2_313C\master 317\CPU 313C\S7 Program(2)\Blocks
Date: 08/11/2011 time: 11:21:18 AM
Compile:
m2_313C\master 317\CPU 313C\Connections
Date: 08/11/2011 time: 11:21:29 AM
Compile:
m2_313C\Device_1(1)\WinCC flexible RT
Date: 08/11/2011 time: 11:21:34 AM
Download:
-> Object was downloaded without errors
Date: 08/11/2011 time: 11:21:43 AM
Download:
-> Object download was executed (with warnings)
Warning: Block 'FC1' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'FC2' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'FC10' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'FC16' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'FC17' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'FC18' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'FC19' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'DB10' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'DB11' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'DB12' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'DB13' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'DB17' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'OB1' already exists on the CPU and has not be downloaded as a result.
Warning: Block 'OB35' already exists on the CPU and has not be downloaded as a result.
Date: 08/11/2011 time: 11:21:51 AM
Download:
Date: 08/11/2011 time: 11:21:52 AM
Download:
-> Error occurred downloading the object
Refer to the log for the single objects for more information.
6. enter in WinCC -> project -> device 1(1) -> communication -> connections. setup address(mpi addr 4) and speed(1.5Mb)
7. create new tag. I want give it addr in DB12.
but I cann't choose it(((((((
what was I don't right??????
And in "connection" I cann't choose station(((((
Re: connect WinCC flex and 313C with PC adapter
in step7 manager open your hmi station,open hardvare config of hmi(your "Configuration"),open if_port ,connect to mpi,save&compile
