Hi all
Im have one problem. Im have CP 5512 and HW adapter.
http://www.imageupload.org/?d=04220EA01
And cable
http://www.imageupload.org/?d=0D8258821
Sometimes I do not know why but it happens when I come to the PLC and only connecting to a connector on the network is now Bus Fault. Where will it be? Not only does not set the connect cable.
Thank you for answer
[?]: CP 5512 Problem witch Profibus
Re: [?]: CP 5512 Problem witch Profibus
It is possible.
network length ?
number of devices ?
1. check terminator switches - at ends must be ON
2. connect to second (free) interface (for example to MPI)
network length ?
number of devices ?
bhole1
Im have 25PLC network on 20 conect standar not problem
only 5 just plug cable and inscriptions BF. I only 5 just plug cable and inscriptions BF.
Terminator is ok.one is to join the peripheral or the PLC is still useful BF.
Conect MPI or other peripheral is it certainly BF.
