[?]: connect CPU313C and WinCC V11 with use PC adapter
Etherlord
Post by Etherlord »
on computer setup Step7 5.5 and WinCC professional v11.
I know what I must check "WinCC -> PC Adapter" in Set PG/PC Interface -> Access Point of the Application.
I cann't change it in PG/PC Interface((((((((((((((
but in project SCADA I can see:
Can You help me?
Re: connect CPU313C and WinCC V11 with use PC adapter
go to control panel -> set pg/pc interface & you can change access point
Homeroid_BL
Re: [?]: connect CPU313C and WinCC V11 with use PC adapter
Post by Homeroid_BL »
Etherlord,
you can not change adapter while in use.
