Request: Wago 750-333 GSD
другие контроллеры
ingjaop
Post by ingjaop »
Hi, I have a module WAGO 750-333, and asks me CoDeSys conectarloal wagob754.gse file, I have the wagob754.gsd but does not recognize.
There are files profibus. Gse?
You can convert a. Gsd to. Gse?
Thanks for your responses.
Umencho
Re: Request: Wago 750-333 GSD
Post by Umencho »
In the GSD files(General Station Description) you get the communication characteristics of a PROFIBUS device. The GSD files get an ident number after certification from the Profibus user organization.
Language-dependent and independent GSD files
With GSD files for Profibus DP you distinguish between language-dependent and independent GSD files. The language-independent GSD files are defined by the extension "*.gsd". Language-dependent GSD files are characterized by the language-related extension of the GSD file.
No.
Extension
Language
1 *.gsg German
2 *.gse English
3 *.gsf French
4 *.gsi Italian
5 *.gss Spanish
So, in your case it should work without any converter.
Best regards,
