[?]: Web Navigator v6.2 on OS of PCS7 licencing problem
krcedinac
Post by krcedinac »
Hello to all,
I recently installed Web Navigator v6.2 on OS of PCS7 contrlol system.
I used EKB 22.05.2011 and installed SIFLA9WSN40602 key for 50 Clients.
When ever I connect I have a following message: WinCC Web Navigator, The Service is currently running in Demo Mode! although the key I installed is active.
Can you tell me what did I do wrong?
Thanks in advance
Re: [?]: Web Navigator v6.2 on OS of PCS7 licencing problem
Need info from logs
C:\Program Files\SIEMENS\WINCC\diagnose
krcedinac
Post by krcedinac »
install
SIFLA9WVC10602
SIFLA9WLB10602
SIFLP7WSV10700
SIFLA9LB100602
krcedinac
Post by krcedinac »
Thanks CoMod.... it is working !
I could not find SIFLA9LB100602 in EKB! Can you please explaing me what was the problem because either ALM or EKB (requested keys) did not point me out what I should install!
If I want to add more then 3 Clients than I suppose I should delete these keys and install others for more clients?
Can you tell me in which file did you see what I was missing?
krcedinac wrote:I could not find SIFLA9LB100602 in EKB!
722 SIFLA9WLB10602
or Search A9WLB1
it is working !
send LOG again for compare
krcedinac
Post by krcedinac »
https://rapidshare.com/files/2292442117/Diagnose1.rar
Can you please answer my questions from previous post?
Yes
mhmdfree2004
Post by mhmdfree2004 »
I want to add more then 3 Clients .
but i can't perform this work
what does he know that i do????
i installed proper licence
please help me
Should i install any license in client computer or not need??
Pokajy
Post by Pokajy »
krcedinac wrote: Image
:shock:
I've same problem. here is my diagnose folder.which licenses do I need?
https://rapidshare.com/files/2893114761/a.rar
thank you
PCS7 or WinCC ?
When your screenshot ?
if key installed Text of License = WinCC WebNavigator (100) |
01/11/2012 12:02:10 ExitLicense RT | AppName = OptRT:WNRT125421 | CycleCheck = yes | Name of License = SIFLA9WSN50700 | Text of License = WinCC WebNavigator (100) |
if key not installed -> See string with Text of License = |
01/11/2012 11:57:55 InitLicense RT | AppName = OptRT:WNLB125171 | CycleCheck = no | NameForMessageBox = | Name of License = A9WLB10700 | Text of License = |
Check these keys in EKB_install
siflA9WLB10700 WINCC-V7 Load Balancing
siflA9LB100700 WINCC-V7 Load Balancing Step Up
siflP7WSV?0701 (SIFLP7WSV40701 PCS 7 - Web Server 25 clients)
Pokajy
Post by Pokajy »
01/28/2012 16:45:46 InitLicense RT | AppName = AppRT:WebDiagServer1486223750 | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WDS10700 | Text of License = WinCC WebDiag Server |
01/28/2012 16:45:46 InitLicense RT | AppName = OptRT:WNPCS71486223859 | CycleCheck = no | NameForMessageBox = | Name of License = P7WSV?0701 | Text of License = |
01/28/2012 16:45:46 ExitLicense RT | AppName = OptRT:WNPCS71486223859 | CycleCheck = no | Name of License = P7WSV?0701 | Text of License = |
(rr) (reread) if key not installed -> See string with Text of License = |
A9WVC?0700 | Text of License = |
you installed siflP7WSV0700 :( remove it
krcedinac
Post by krcedinac »
Hello CoMod again after long time,
Same story PCS7 v.9.0 installed all keys for web navigator but it keeps giving message The Server is currently in Demo Mode.
I used keys from EKB 10.08.2017 for PCS v.9.0
What data you need this time to tell me what to install?
Thanks in advance
Need info from logs
Rex2701
Post by Rex2701 »
Have you used WebNavigator or Web Server licenses?
In my case, PCS 7 v8.1 Web Server won't to accept "WinCC/WebNavigator for 25 clients license" (6AV6371-1DH07-3CX0) and wants "PCS 7 Web Server" licenses only (6ES7658-2GE00-0XB0 for 1 client, 6ES7658-2GF00-0XB0 for 5 clients or 6ES7658-2GG00-0XB0 for 10 clients).
krcedinac
Post by krcedinac »
Hello CoMod,
Here is a link:
https://we.tl/t-L8TuO7PaVZ
Re: [?]: Web Navigator PCS7 licencing problem
install next keys
krcedinac
Post by krcedinac »
Hello CoMod,
I saw that file but did not check which are the licences in EKB. I added those on your screenshot , after it asked for three more and now it works.
We need to put 7 different keys in order to make it work (h)
Thanks for your help...again!
rakeshee
Post by rakeshee »
CoMod wrote: Wed Oct 03, 2018 3:30 pm install next keys
Can you please share the image again?
