[?]: Random inputs
ravender
[?]: Random inputs
Post by ravender »
Hello everyone!
I have a program.. for example:
A i0.0
= q0.0
a i0.1
= q0.1
a i0.2
= q0.2
I want to shuffle those inputs random after pushing a button.. so after button press those code should look like:
a i0.2
= q0.0
a i0.0
= q0.1
a i0.1
= q0.2
How can I make such effect?
saravanan_tsvk
Re: [?]: Random inputs
Post by saravanan_tsvk »
Spoiler
A i0.0
= q0.0
a i0.1
= q0.1
a i0.2
= q0.2
a i0.2
= q0.0
a i0.0
= q0.1
a i0.1
= q0.2[/spoiler]
How can I make such effect?[/quote]
Where do u want this kind of logic.
For your requirement it is good to use the memory bits instead of the direct DI's.
Use the Shift/Rotate instruction to shift the bits in the DI's and move the output value to the Memory location (M - bits) and use the M-bits at the actual logic.
