[?]: MS SQL 2005 SP1 for PCS7 v7.0/WinCC v6.2 set up problem
maher
Post by maher »
Hi all
After downloading the ( MS SQL 2005 SP1 for PCS7 v7.0 (WinCC v6.2) )
I collect in the folder and I am trying to install it the following wrning messages are appeared to me and the installation aborted are requested .
(h) (h) (h) (oo) (oo) (oo)
my windows is xp sp2,
please, tell me what can i do ???????????????????
regards,
maher
van_vin
Re: MS SQL 2005 SP1 for PCS7 v7.0 (WinCC v6.2) set up proble
Post by van_vin »
Dear Mr. maher
Make sure you named your folder using English alphabet and small length.
Oldman
Re: [?]: MS SQL 2005 SP1 for PCS7 v7.0/WinCC v6.2 set up pro
Post by Oldman »
install the software from the disc C:
maher
Post by maher »
In the first and before every thing thank you for your support , SQL IS installed right.
But sorry when I tried to install PCS software, I got the following messages( I can't find IIS file to install it )
Best regards,
Maher
See README
Do you need to install the Option Pack for Windows for installation of the Internet Information Server (IIS)?
"Start > Settings > Control Panel > Software" and then pressing the "Add/Remove Windows Components" button.
Note
More details are available in the manual "SIMATIC HMI WinCC Web Navigator V1.1" in Entry ID 2053005.
maher
Post by maher »
where are these batches please,
Maher
