How to read IEEE format INTEL Litter Endian in PcVue?
leofarhan
Post by leofarhan »
I am using PcVue 8.1 for reading some exteranl devices on ModBus TCP/IP, I have to read the floating registers available in the device the floating format is "IEEE format INTEL Litter Endian"
When I read the incorrect value appears in the PcVue. Have tried to use Real with Mlsb & Lmsb (i.e. LSB/MSB First) But it did not work.
Can anyone guide me how can I read the data? Is there any instruction in SCADA Basic Program of the PcVue to convert IEEE 754 Float to IEEE format INTEL Litter Endian.
Looking forward for your reply.
BR
Leo-Ali
leofarhan
Re: How to read IEEE format INTEL Litter Endian in PcVue?
Post by leofarhan »
Hello!
The following VB code can be used to convert IEEE-754 Intel Endian format into IEEE-754 Intel Big Endian in the PcVue.
For this two registers need to be configured, one for reading the value from device (Used as hex number) other the float as output of the program.
Spoiler
Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (Destination As Any, Source As Any, ByVal Length As Long)
Const cVARIABLES_NUM = 1
'Number of variables to subscribe
Dim WithEvents Obj_NewValue As CLS_Subscription 'Object used when a value change
Private arstrVarNames(1 To cVARIABLES_NUM) As String        'Array containing the variables to subscribe
'Dim WithEvents vMyVar As Variable
Private Sub fvProject_StartupComplete()
'    Set vMyVar = Variables("TEST")
'    vMyVar.EnableEvents = True
    'Here we create an array containing the list of variables to subscribe
        arstrVarNames(1) = "Variable_Name"
        'Call the subscripion function
        Set Obj_NewValue = ConnectSubscription
End Sub
'To Initialize the variable name and value arrays
'- using arStrVarNames : Array of variables to connected
'- (out) ConnectSubscription : Subscription object created to connect the variables
Private Function ConnectSubscription() As CLS_Subscription
 On Error GoTo TRAP_Error
 'Initialize the Subscription object to be returned to the caller
 Set ConnectSubscription = Nothing
 'No Subscription currently executed, so a new one can be created
     'Create the Subscription object
     Set ConnectSubscription = New CLS_Subscription
     'If connection succeeds, initialize the Subscription object to returned to the caller
     If ConnectSubscription.ConnectVariables(arstrVarNames) = False Then 'If connection failed
         ConnectSubscription.Clear
     End If
On Error GoTo 0
Exit Function
TRAP_Error:
 MOD_General.ErrorManagement "ConnectSubscription", "ThisProject"
End Function
'Sub : Obj_NewValue_OnRefreshed
'Scope : When a value change the procedure is called
'Parameters :   arstrVarNames --> Array containing the variable name
'               arStrVarValues --> Array containing the variable value
'Caller : EVENT
Private Sub Obj_NewValue_OnRefreshed(arstrVarNames() As String, arStrVarValues() As String)
Dim strHexNumber As String
Dim strTmp As String
Dim sglYourNumber As Single
    strTmp = Hex(arStrVarValues(0))   'AA BB CC DD
    'Check if the strTmp having 0's in start, the number of HEX characters will be reduced (i.e. less than 8)
    'If number of characters of strTmp are less then 8, add zeros in start to complete 8 characters
    '---New code
    If (Len(strTmp)) < 8 Then
        For x = 1 To (8 - Len(strTmp))
            strTmp = "0" & strTmp
        Next
    End If
    '---End new code
    'swap the bytes for Little Endian: DD CC BB AA
    strHexNumber = Right$(strTmp, 2) & Mid$(strTmp, 5, 2) & Mid$(strTmp, 3, 2) & Left$(strTmp, 2)
    sglYourNumber = StringToSingle(strHexNumber)
    Variables(arstrVarNames(0) & "_REAL").Value = sglYourNumber
On Error GoTo 0
Exit Sub
TRAP_Error:
 MOD_General.ErrorManagement "Obj_NewValue_OnRefreshed", "ThisProject"
End Sub
'Private Sub vMyVar_ValueChange()
'Dim strHexNumber As String
'Dim sglYourNumber As Single
'    strHexNumber = Hex(vMyVar.Value)
'    sglYourNumber = StringToSingle(strHexNumber)
'    Variables("TEST_REAL").Value = sglYourNumber
'End Sub
Public Function StringToSingle(ByVal strNumber As String) As Single
Dim a(4) As Byte
Dim z As Integer
For z = 0 To 3
    a(z) = CInt("&H" & Mid$(strNumber, (4 - z) * 2 - 1, 2))
Next z
CopyMemory StringToSingle, a(0), 4
End Function
BR
Leo-Ali
shaikh_rehan
Post by shaikh_rehan »
Please tell me is it possible to read the IEEE754 format in PC Vue...?Can PC vue understands the double prescion IEEE754 format..?
