Hello friend's, my customer send via mail to me a WinCC runtime project but do not know how version has been used to develop the project
If i open the project with WCC 7.0 , no problem, but if i modify this project with a incorrect version when will load a modified project , does not work.
It's possible to know the version of wcc from project ?
thank you to all
[?+]: How to know the WinCC version of runtime project?
PLC_ITA
Re: [?]: How to know the WinCC version of runtime project?
See *.dcf
For earlier versions WinCC <6.2 do not have this tag[Version-Number]
SV.07.00.00.00
PLC_ITA
my project probably is v6.0 or v6.2 (service pack ?)
do you know a method to read a version ?
Scowl
Maybe your customer can see it in the windows menu Start, Folders: SIMATIC->Information->Installed software.
Umencho
Use this VBS-Code in order to display (version, service pack, update) from RT this information in splash window.PLC_ITA wrote:my project probably is v6.0 or v6.2 (service pack ?)
Set WSHShell=CreateObject("WScript.Shell")
strWinCCVersion = WSHShell.RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\SIEMENS\AUTSW\WinCC\VersionString")
Easier way is to hold on the mouse on the .pdl and you get the information from the tooltip..
program files -> siemens> wincc > wincc projects
Under your project folder ----> gracs -------->
open any pdl and search for version...
PLC_ITA
Thank you
You are a professionist !
