[LINK]: old Microwin 16 v2.1
alireza136110
Post by alireza136110 »
hi dear friends.
i need old Microwin 16 v2.1
http://support.automation.siemens.com/W ... en/4071710
The SIMATIC STEP 7-Micro/WIN, Version 2.1 Programming software for the S7-200 Micro PLC will be cancelled on October 1, 2001.
SIMATIC STEP 7-Micro/WIN Ver. 2.1 is a predecessor of the current STEP 7-Micro/WIN32 Version 3/4 Software
can every body help me?
plz.
thanks
alireza136110
Re: Request: old Microwin 16 v2.1
is there anyone help me?
microwin v 2.1
Daniel_Brasil
Post by Daniel_Brasil »
Hello alireza136110,
Here is the software you need (Siemens - Step 7-Micro/WIN32 Version 2.1 Multilanguage).
[dead] megaupload.com/?d=4D7YEJIL
Good luck,
Daniel
alireza136110
Re: [LINK]: old Microwin 16 v2.1
hello Daniel.
thanks.
bestregards.
alireza
edwardmanurung
Post by edwardmanurung »
Is anybody still have the old microwin 16 or 32 v2.1..??
Im very need it (oo)
alireza136110
[dead] STEP_7-MicroWIN_V21
ermione
[Request]: Step7 MicroWin v 2.1 year 2000
Post by ermione »
Hello.
I have a project made with Step7 MicroWin 2.1 (about year 2000) that I need to open (mostly to read program comments) but I don't have access to the software.
Current versions cannot open it.
Someone can help?
Thank you in advance!
Link
Forum Community
Forum Community
Re: [Request]: Step7 MicroWin v 2.1 year 2000
Post by Link »
microwin 3.2 will help you?
installation it isn't checked, you will try.
https://mega.nz/file/ZIkWhCrC#XtmwWSw4h ... 1lwVwfXcLE
please write if installation ok and if it`s solved your problem.
ermione
Post by ermione »
Hello!
Thank you very much for sharing.
I can confirm the software install successfully (on a virtual machine Windows XP 32 Professional SP3).
What's in the package is:
MicroWin v.3.2.0.105
Hotfix for v.3.2.0.105
Upgrade to 3.2.1.34 (it requires a previous version installed, like the supplied 3.2.0.105, and then uninstalled - or a different program folder selected)
"Tips and Tricks" (S7-200 Application Examples)
Unfortunately however, while this version might open some 2.1 projects, it doesn't work with mine. It say that my project use a feature (symbolic addressing) that's
not available in the 3.x version and I should open the projecy with 2.1, disable the feature and save it. Then it could be opened with 3.x
But I don't have the 2.1... So please if you find it in a old CD (I have been told that the V4.0 original CD might have it in a folder "old versions") share it!
Best regards!
rualcosi
Post by rualcosi »
Hope that this can help you. Siemens S7 MicroWin 16 v2.1.
Let me know if it's working.
[dead]
https://mega.nz/folder/Uv51mQya#xfcc0ECVEGGqnel_mwYdDA
ermione
Post by ermione »
Hello!
It works perfectly (on a virtual machine Windows XP 32 Professional SP3) and it opens my project!!!!
Simply perfect.
Thank you again!
pimpo
Post by pimpo »
Hello, I'm also in need of this old MicroWin, I have V3 and V4, but need to open an old project.
The link from rualcosi, has only an empty folder. Can you put it again, please, the V2.1 or lower.
ntldr123
Post by ntldr123 »
Can you upload MicroWin V2.1 or lower?
rualcosi
Post by rualcosi »
Here you have again.
Hope it help how need it.
