Dear forum members,
Could you please suggest me where to get some sample projects for WinCC Flex 2005?
Regards
[?]: sample projects for WinCC Flex 2005
- Faq & Info
Re: [?]: sample projects for WinCC Flex 2005
Siemens replace old Demo 2005 by new Demo 2008
http://support.automation.siemens.com/W ... n/22900091
for old 2005 SP1 versions
[dead] :/3413436774/ ... 005SP1.zip
[dead] :/1453389267/ ... 005SP1.zip
See WinCC Flex 2005 CD folder
\Documents\English\Getting Started
Dear Info,
Thanks for the reply.
I retrieved those projects from the folder you suggested.
But I cannot download the files from rapidshare ... it asks me to wait for 5min and then says something like "....could not find connection to the server ...".
Just 1 request - How do I connect these 3 applications for simulating small projects for trial only :
S7 v5.4 sp1
S7-PLCSIM v5.4 sp2
Wincc flex 2005 standard sp1 hf6
Please advise / I will appreciate if you could give steps to have them "talk-to-each-other" so that I could simulate small programs.
I never tried WinCC Flex 2005 ever before.
Regards
S7 v5.4 sp1
S7-PLCSIM v5.4 sp2
Regards
- Faq & Info
How do you integrate a WinCC flexible project in STEP 7?
http://support.automation.siemens.com/W ... n/38797080
Dear Info,
Thank you very much for the link. I was able to "put them together" after following those instructions. Infact , I simulated a small program of Motor start-stop on it.
Additionally, can you advise me on how to close the WinCC Flex RT window? Is it ok to click the "X" (close window) or there is a provision to shutdown by a proper procedure?
As I said , I simulated a very simple program of starting and stopping a motor.
But if I want see moving objects like movement of a conveyor or a hoisting machine, do I need to write a script for this kind of animation? (This's my first attempt with WinCC so please bear with me !!!)Kindly advise any additional downloads or sample projects for getting familiar with this application.
Regards
Regards
