maher
Posts: 112 Joined: Fri Aug 29, 2008 8:44 pm
Post
by maher » Wed Jun 15, 2011 6:18 am
Hi all
I cann't access to the modules ( when I entered to H.W iI found cross on the modules ?????
so what is the reasons for that ?
Also I have image but i cann't upload it to here,could you tell me how can I make this ?
Regards,
Maher
PLC_ITA
Posts: 269 Joined: Sat May 27, 2006 6:46 am
Post
by PLC_ITA » Thu Jun 16, 2011 8:49 pm
stay quiet !
here there are people that work for all GRATIS ! You cannot require an answer after 6 hours !!
Check if the hardware code is correct. If is correct recompile and download the hardware config
peterc101
Posts: 34 Joined: Mon Oct 11, 2010 12:54 pm
Post
by peterc101 » Thu Jun 16, 2011 10:08 pm
PLC_ITA is right you got a wrong harware configuration or you just forgot to download it
maher
Post
by maher » Sat Jun 18, 2011 9:48 am
PLC_ITA wrote:
stay quiet !
but i had got this problem after I uploading the program, so is it right to download again what I uploaded after ( save & compiling ) process
Maher
