I have 412-1 CPU and the default memory is 288 Kbye, divided into 144 Kbyte for data and 144 Kbyte for program
But i need to increase the program memory to 180 Kbye ....is it available in Step 7 software or not ?
Note
Simatic version 5.1
[?]: I need to the change memory size in CPU 412-1
FECUMSAYED
Re: [?]: I need to the change memory size in CPU 412-1
Do you have 2 ways:6ES7412-1XJ05-0AB0
CPU412-1, MPI/DP, 288 KB
SIMATIC S7-400, CPU 412-1 CENTRAL PROCESSING UNIT WITH:
288 KB WORKING MEMORY,
(144 KB CODE, 144 KB DATA),
INTERFACE MPI/DP 12 MBIT/S
optimize the program
or buy a more powerful processor - this is the concept of processor range of Siemens
more memory - more than the price
6ES7414-2XG04-0AB0
SIMATIC S7-400, CPU 414-2 CENTRAL PROCESSING UNIT WITH:
512 KB WORKING MEMORY,
(256 KB CODE, 256 KB DATA),
1. INTERFACE MPI/DP 12 MBIT/S, 2. INTERFACE PROFIBUS DP
6ES7417-4XT05-0AB0
SIMATIC S7-400, CPU 417-4 CENTRAL PROCESSING UNIT WITH:
30 MB WORKING MEMORY,
(15 MB CODE; 15 MB DATA)
1. INTERFACE MPI 12 MBIT/S, 2. INTERFACE PROFIBUS DP, 3./4. IF IFM MODULES PLUGGABLE
FECUMSAYED
Dear Sir
Thanks for your help and support,
Can I increase the memory by adding RAM memory card (Order Number is: 6ES7 952-1AHO-0AA0), this order number is compatible with my cpu
I just need 2000 Byte only above the CPU memory
Note
the cpu data
6ES7412-1XJ05-0AB0
thanks
Note
the cpu data
6ES7412-1XJ05-0AB0
thanks
saravanan_tsvk
Sorry, adding a RAM memory card can only increase the size of the Load memory and it cannot do any thing with the Work memory of your CPU.
Only way is to optimize your program.
