Hallo,
I'm trying to make the communication between my TP177B and WinCCFlexible 2008 and I'm have not results, I did all of modifications I tryed to communicate with Ethernet, MPI/DP.
I changed all addresses in WinCC and in OS in a TP177B and the program can't communicate. I've a old program in that panel, and now I'm using it for other application but I can't change the files in the TP177, someone can help in that problem.
THX.
[?] Communication between TP177B and WinccFlexible
sobanski
dsekulic
Re: [?] Communication between TP177B and WinccFlexible
Did You make appropriate adjustment in WinCC Flex (Communication -> Connections). There You can set communication parameters for Your panel (Interface, Panel and PLC address). Did You make Your connection to On on Active field. Also You can make hardware configuration in Step7 and integrate panel with PLC program. Also You can start WinCC Flex from Step7. One more thing You also should check. Go on Start -> All Programs -> Simatic -> Step7 -> Setting the PG/PC Interface. There You should adjust communication channel over which You want to communicate with PLC.
regards
regards
