[?]: connect Panel View Plus 1250
temo281284
Post by temo281284 »
Dear Frinds
I have a project that contains an Allen Bradley Panel view plus 1250
What do i need to connect to this panel and upload the program from it :roll:
I have FactoryTalk View ME software and P2P serial cable, But i couldn't connect till now
please help as soon as possible
Rock_manp
Re: Panel View Plus
Post by Rock_manp »
The panelview Plus is primarily Ethernet. You will need to set the IP address of the PanelView and the IP address of your computer and use a crossover cable or an Ethernet switch/hub.
cuongvcs
Re: Panel View Plus
Post by cuongvcs »
hi you .
you can use Transfer Utility of Factory Talk View ME tool to download and upload application with RS232 serial cable .
or you can use USB .
for use USB you can convert application file .apa to file .mer and copy application in to Panelview memory .
when you connect the USB for Panelview, it will automatically create folders .
EX : I:\Rockwell Software\RsViewME\Runtime
then you can use it.
good luck (thnx) (thnx) (thnx)
