[?]: Programming for Rec523 use CAP505
другие контроллеры
nguyenhung1811
Post by nguyenhung1811 »
Hi everybody, I have to use Rec523 to control three feeder.
But now i can't find user guider for my program and I need Technical Descriptions of Functions 1MRS750889-MCD of ABB to help me know how to use function control in CAP505.
If some1 has this, please give. I very appreciate if you help me.
Thank you a lot:) (gogle) <= I try to find from google but I could see any thing. :(
Linkinx64
Re: Programming for Rec523 use CAP505
Post by Linkinx64 »
Good afternoon.
nguyenhung1811 wrote:i can't find user guider for my program and I need Technical Descriptions of Functions 1MRS750889-MCD of ABB to help me know how to use function control in CAP505.
The referenced number (1MRSxxxxxx-MCD) is a removable media (CD). What you need from that CD to start (re)configure REC523 is this manual: http://depositfiles.com/files/7xkc3cn6s (Protection & Control Terminals REF 54_, REM 54_, RET 54_, REC 523 - Configuration guideline)
Start read from "Editing the relay configuration" chapter.
Regards, Linkinx64
nguyenhung1811
Thank you. But I need Technical Descriptions of Functions 1MRS750889-MCD to know how to use control function block. That's the 1MRS750889-MCD in CD-rom but I didn't have this CD-rom, so if you have this file or this CD, plz send me again. thanx very much.
mytom123
Re: [?]: Programming for Rec523 use CAP505
Post by mytom123 »
Hi
I think it is difficult to find this file, but with this file you can see all of function blocks are used in REC523:
http://www.abb.com/product/db0003db0042 ... 401ab.aspx
If you have some experience with ABB relays, you can see in some instruction description of function block in other ABB relays, you can understand how is function block of REC worked.
We hope that a guy has this manual and upload it.
Brgds.
Linkinx64
Post by Linkinx64 »
Hello
I don't have CD but I have CD TOC (contents).
Some of the documents listed in TOC I have on HDD.
You can tell me doc number (1MRSxxxxxx), I will check and if I have it - will upload.
nguyenhung1811
Maybe I need this 1MRS750889, but I didnt see in your list. Another way,can u send me this file 750528, I think i need it too, thank you for ur enthusiasm.
Linkinx64
Post by Linkinx64 »
nguyenhung1811 wrote:Maybe I need this 1MRS750889, but I didnt see in your list.
This is CD, not document.
nguyenhung1811 wrote:Another way,can u send me this file 750528,
This document I don't have on disk. Sorry :?
mytom123
Post by mytom123 »
I have this document.
You can download here.
http://www.mediafire.com/?jk2hibqwls213sr
Chao VietNam.
nguyenhung1811
mytom123 wrote:I have this document.
Chao VietNam.
:D, cam on nhe ban. Ban dang lam viec o dau the\
nguyenhung1811
Thank you for your help.
spak
Post by spak »
Maybe somebody has 1MRS750745 document?
mytom123
Post by mytom123 »
spak
Post by spak »
thanks mate
