Hello friends, i need an little help to install TIA V11
I have downloaded the package, decompress : OK
Installation of the TIA : OK
only one error is displayed ---> "LICENCE ERROR" , but i think because i do not install the licence.
install the licence : OK
during the startup of TIA 3-4 after the start, a message is displayed : AN ERROR IS OCCOURS and there are 2 buttons : RESTART or END
I do not understand why !
I use WIN 7 Ultimate on a VMWARE virtal machine whit 40 Gb of Hd and 1,5 Gb of ram
for 3 time i have tryed but the result is the same
Anyone have a suggest for me ?
Thank to all
[?+]: bugs when install TIA v11 with notEnglish language
PLC_ITA
Re: A little help to instal TIA v11
Try to reinstall and select REPAIR option
I use free Oracle VirtualBOX www.VirtualBOX.org
niila
Re: help to install TIA V11
hi
i think your problem related with your operation system.
if you installed on professional you wouldnt see that problem.
it s just my opinion.
alafandy
try again with Install TIA V11.0
and when come windows for key...( just skip it )
as seen in pic
and when finished Restard PC
i hope u fix it..
as seen in pic
i hope u fix it..
alafandy
Re: [?]: help to install TIA V11
why you dont upoad pic of your problem
anyway,...maybe you must make windows feauture ON
and must Have SQL sever 2005 in your pc
and hack as shown here in pic
maybe help you
maybe help you
PLC_ITA
Step7? WinCC ?PLC_ITA wrote:This is my alarm.
I'ts in italian, in english is :
An errors are occours, and the application is closed. Do you want to restart ?
need more info - Windows *, antivirus ?
see LOGs
C:\Documents and Settings\All Users\Application Data\Siemens\Automation\Logfiles
PLC_ITA
Re: A little help to install TIA v11
thank you for your interest,
I have tryed to install into Window 7 ultimate but also in Windows 7 Professional
with same result.
In both try i have used WmWare virtual Machine .
I have istalled only TIA V11 no Wincc , and no other package ( antivirus or other )
tomarrow i search into "logfile" .
Anyone have installed a TIA with success in Win 7 italian version ?
My be there are a problem in Italian language....
I do not undertand where is my problem !
with same result.
I use free Oracle VirtualBOX www.VirtualBOX.orgPLC_ITA wrote:thank you for your interest,
with same result.
PLC_ITA
Nothingh to do. The same error also with Virtualbox.
Now i re-download and retry
Anyone have an idea ?
What should you watch out for when installing STEP 7 Basic and Professional V11.0?
http://support.automation.siemens.com/W ... n/50204569
Try WinXP
Try WinXP
kphcm
I be the same your error because my file download error(Check by CRC on file).
Please check CRC on all of your files you download before you install
good look
good look
PLC_ITA
thank you KPHCM, but i think that my package is good.
I have find a solution :
For my experince, the problem is in italian language.
First install in english only, and then repair and add italian . All OK
I do not why, but after this success, only for test i have re try to install directly in italian, and the error is displayed.
Thank you to all for every suggest
lalo_377
Re: [?+]: bugs when install TIA v11 with notEnglish language
I had the same problem but my OS is Windows XP SP3. I found in the Simens Support a file to fix it, but I don't know if woks to Windows 7. Here is the link: https://www.automation.siemens.com/WW/f ... age=en#top
Step 7 v11 - Continuous restart error message
In an attempt to resolve the issue you are seeing with Step 7 v11, can you please implement the following;
1) Save the attached file to your local hard disk and then extract the S7DOS del reg if error 1605.re_ file.
2) Then rename the S7DOS del reg if error 1605.re_ file to S7DOS del reg if error 1605.reg
3) Double click the S7DOS del reg if error 1605.reg file and click 'Yes' to add the information to the registry and 'Ok' the execute message.
4) Run a repair of the Step 7 v11 install
Note: Always take an export (backup) of your registry before making any changes to it; please refer to http://support.microsoft.com/kb/256986 on how to do this.
Then test the Step 7 v11 install, it should now run without error?
S7DOS del reg if error 1605.zip
https://www.automation.siemens.com/WW/f ... anguage=en
