hallo,
I need to read a incremental encoder in a system with a CPU 400 6ES7 414-3XM05-0AB0 FW 5.0, I need to know how can I read that encoder in my system.
I use a system with ET200 S in field, so if someone can help I thx a lot.
THX
[?]How can I read incremental incoder in a S7 400 system
sobanski
hmi222
Re: [?]How can I read incremental incoder in a S7 400 system
Yu can use this module:
ET200S 1 Count 24v DC module ( 6ES7 138-4DA04-OABO )
or
6ES7138-4DL00-0AB0 wrote:SIMATIC DP, ELECTRONIC MODULE
SIMATIC DP, ELECTRONIC MODULE FOR ET 200S, 1 POS U, CONTROLLED POSITIONING WITH DIGITAL OUTPUTS FOR 5V/24V INCREMENTAL ENCODER, SSI-ENCODER, 30MM WIDE
http://support.automation.siemens.com/W ... en/9264159
sobanski
Thank you but I dont have this one but it work equal or better than de other module.sania wrote:or6ES7138-4DL00-0AB0 wrote:SIMATIC DP, ELECTRONIC MODULE
Thx
sobanski
Thx a lot I'll use this module in my configuration, because I've this one in my warehouse.hmi222 wrote:Yu can use this module:
When I use this module, how can I read the information. Somebody can send me a example of software.
THX
sobanski
Someone can help me on it, becaus I've no idea how can I make it work, because the SFB's that I've availible doesn't work with the kind of CPU that I've here. So I need to know how that module work.
THX
THX
hmi222
sobanski:
http://support.automation.siemens.com/W ... nload=true
So then give the Simatic Support a chance wink:So I need to know how that module work
sobanski
Thx I saw now how the bits work in that module.
Thank you
Thank you
