Will anyone supply LD 800HSE FF configuration file with suffix".cfh" for me?(A .cfh file of LD 800HSE FF download from web Foudation Fielbus,when add to FF builder,it can't be imported)
And does anyone have LD 800DP DP configuration file?
Thanks advance.
And my Email:xxy811225@hotmail.com
[LINK]: LD 800HSE ".cfh"file
http://www.mediafire.com/?l70y62akmm95atkHOUYI wrote:LD 800HSE FF configuration file with suffix".cfh"
Re: Ask for LD 800HSE ".cfh"file?
Tanks a lot.
But still a error occured as .cfh file from web foundation fieldbus when import
screenshot
screenshot
Re: [LINK]: LD 800HSE ".cfh"file
Your screenshot already contains an answer: check for updates.
Try update FF Builder to a newer version.
You may also open .cfh file in notepad and change "," to "+". in a proper string (the 137th string from beginning) . After that error will disappear. But I'm not sure this is a valid action...
