Dear experts,
I cannot download s7-200 programs to its simulator.
There comes a small window saying "Port not found or it is in use by another application"
Someone plz give a remedy and tell me what are the steps to connect to the simulator and download your programs to it (in case if I'm doing something wrong in my procedure !!)
Thanks and Regards
[?]: s7-200 simulator connection problem
Homeroid_BL
Re: [?]: s7-200 simulator connection problem
Hi!
Which simulator are you using? Generaly, there are no problem with ports in simulators.
Dear Homeroid_BL,
Thanks for your response (and sorry for the delayed reply from my side which was due to some issues with my registration and I sincerely thank the Moderators /Administrators for their professional assistance)
I'm using s7-200 version 2.0 downloaded from http://personales.ya.com/canalPLC
Any suggessions?
Regards
Any suggessions?
Regards
I gues you want to download the PLC program from Microwin to simulator.
Is not possible.
You must create a program source, and then select that file to be loaded from simulator.
All the best,
Is not possible.
All the best,
From MicroWin program you have created previously, you should perform:
File....Export ( now you have *.awl file which is usable in simulator)
I hope this would help.
