[?]: 800xA Device library, about import FF,PA,hart DD?
другие контроллеры
HOUYI
Post by HOUYI »
800xA Device library,about import FF,PA,hart Device description(shortDD) file?
How to import 800xA device description file?800xA online manual said:firstly,download exe or zip file of FF,PA,Hart DD from solutionbank.abb.com .But even if log in this web, "download" is not enabled.
------Following is how to download DD file said by 800xA online manual.-----
Use the Device Library Wizard to extract the device type files on the system nodes.
800xA System DVD 2
The device types available at point of time this 800xA system version has been released are stored on the second delivered system DVD. The device type files are separated in the specific folders related to the fieldbus protocol.
Download from the ABB Solutionsbank
1. Login to ABB Solutionsbank, http://solutionsbank.abb.com
2. Open Download Bank > Download Bank Explorer
3. Browse to
? Control Products and Systems / 800xA / Device Management - FOUNDATION Fieldbus / Device Library - <category>
for FOUNDATION Fieldbus device types or
HART / Device Library - <category>
for HART device types or
? Control Products and Systems / 800xA / Device Management - PROFIBUS / Device Library - <category>
for PROFIBUS device types
Through instrument index of ABB web,download zipped file of PA and Hart DD,zipped file can be extracted by ABB device library.But the zipped file of FF DD cannot be extracted, when extract it, come up a tip means the FF DD file is invalid, but I don't think the FF DD file is damaged,so I want know why?
Linkinx64
Re: [?]: 800xA Device library, about import FF,PA,hart DD?
Post by Linkinx64 »
Try to add library manually:
1. Load all required system extensions with Configuration Wizard -> System Administration -> System Extension Load.
2. Unpack library with Winrar.
3. Copy whole unpacked folder to C:\Program Files\ABB Industrial IT\Engineer IT\ABB Device Integration Library\FF Device Integration Library.
4. Use ABB Device Library Wizard -> Device Type Administration to load .afw file to the 800xA system.
regards
HOUYI
Post by HOUYI »
Your Kindness is appreciated.I'll try and hope it will do
"Use ABB Device Library Wizard -> Device Type Administration to load .afw file to the 800xA system"
hOW can i access to"Device Type Administration "?
Linkinx64
Post by Linkinx64 »
HOUYI wrote:hOW can i access to"Device Type Administration "?
This is it:
Remark to the pervious post: the folder name may be a different. It depends on the device communication standard: Profibus, FF or HART (in the example above - folder for the devices connected via FF).
HOUYI
Post by HOUYI »
There is no device type administrator,but "select system".
as the follow picture
800xA V5.01 used.
And I want know how to solve it?
Linkinx64
Post by Linkinx64 »
HOUYI wrote:There is no device type administrator,but "select system"..
I use 800xA SV5.0.2, that's why.
For 800xA SV5.0.1 choose Select System. In the next window select type of supported system and click Next.
After system is selected you click Install Device Types, choose protocol (Profibus, FF or HART) and in the list of available devices you'll see device which has been copied to C:\Program Files\ABB Industrial IT\Engineer IT\ABB Device Integration Library\FF Device Integration Library
regards
HOUYI
Post by HOUYI »
Firstly,Thanks for your rely.
"For 800xA SV5.0.1 choose Select. In the next window select type of supported system and click Next.
After system is selected you click Install Device Types, choose protocol (Profibus, FF or HART) and in the list of available devices you'll see device which has been copied to System"
The device list is null,even if I have copyed DD/GSD/EDD file to the following folder
C:\Program Files\ABB Industrial IT\Engineer IT\ABB Device Integration Library\FF/Profibus/Hart Device Integration Library.
So I want to get your idea?
As the official net is not support upload,so now I attach the screenshots.
AS the last picture show above,Abb service status :red with "x',will denable the device libarry work normally.
Linkinx64
Post by Linkinx64 »
Can you upload this device file?
In this case we can check it out on working system and probably solve this problem.
HOUYI
Post by HOUYI »
Certainly, but I cannot find it support upload attachements this forum, or maybe I don't have this authority.
So I upload them to rapidshare and mediafire,and attach the link here.
https://rapidshare.com/files/458488324/DD.rar
http://www.mediafire.com/?dj7e36k76e5jugf
After unpack DD.rar, you can find the following device description file.
I can send them to your mailbox if you leave your email here,and my email:xxy811225@hotmail.com.
Linkinx64
Post by Linkinx64 »
These files does not appear to be a 800xA device object types.
Device types (to be controlled by AC 800M, Asset Monitoring environment or Freelance) in 800xA must have at least one .afw file in"import" folder and xml-descriptor.
Example:
Example file: http://www.mediafire.com/?6e03sju4snmzlyl
In ABB's solutionbank device types for 800xA can be selected from the Download Explorer-> Control Products & Systems -> 800xA -> Device Management HART/Profibus/Foundation Fieldbus/ IEC 61850.
The GSD/FFO (in your archive) files are usually used for the device settings description when programming PLC or communication modules, not an 800xA aspects.
HOUYI
Post by HOUYI »
Thanks for your instrction.
yamotorola
Post by yamotorola »
Dear All !
Can you send to me some project ABB control builder 5.1
Thanks All !
