how to transform variable coding on 2 INT type to 1 REAL t
ced1104
Post by ced1104 »
Using the Applicom card to communicate with PLC, I need to transform a variable coding on 2 INT type to 1 REAL type
To communicate with PLC, I used a buffer composed by array of INT. I send a real variable to the applicom card using a frame coding on 16bits, but when I want a recover this variable coding 32bits with masks, I lost the floating comma type.
What can i do to recover the value of my variable into real type. You know if in Rslogix5000, a function exists to recover the state of my real variable
dehell
Re: how to transform variable coding on 2 INT type to 1 REA
Post by dehell »
Try this code
[dead] :/455885248/int_to_real.JPG
Regards
ced1104
Post by ced1104 »
Thanks your response I will try it
ced1104
Post by ced1104 »
The Applicom driver converts my real into 2 INT coding floatiing comma. I search a solution to recover the value of my real variable.
