[?+]: How to crack the password for a LOGO plc?
singleperson
[?]: Crack Password Logo soft Siemens
Post by singleperson »
Dear All,
Please help me
I need software,which can remove password PLC Logo Siemens
I want to upload programing but I can't.Because it's Protected Password
Thanks and best regards
dekor
Re: [?]: Crack Password Logo soft Siemens
Post by dekor »
Dear friend,
you may use the programm called LGCommSpy++ if you use serial port.
I don't know anything about USB cable....
First Install, then run this program, on the same time run the Logosoft and try to comunicate with the PLC.
When you try to connect to PLC will be asked for password.
Do not enter any password. Just look now to LGCommSpy++ and you will read immediately the Logo password.
Now go back to Logosoft and use the password.
The link for LGCommSpy++ is: http://www.i.com.ua/~mitech/LGComSpyInst.exe
Keep us informed .
dekor
singleperson
Thanks your support. Thank you very much
I hope it's success.
Because I use cable connected to Personal Computer by USB when I connected to Logo.
Thank you
dekor
Post by dekor »
do you want tell us what was the experience with USB cable?
dekor.
koorosh
Post by koorosh »
I have the same problem
korosh. from iran.
dorofteius
Post by dorofteius »
It work's whith usb too, but not whit this program.
Device monitoring studio does the job. ( it is a com sniffer, or spy ).
My question, I have logo 24 rc, brand new> Made a copy from another,write'd in this one, but the program clear's (autoerases) every time after I remove the power. Abnibody knows the problem?
hand_drake
Post by hand_drake »
Can somebody help to share how to crack PLC LOGO! password.
I have search for it before but there is no clear answer.
Please help. (wow)
dekor
Re: [?]: How to crack the password for a LOGO plc?
Post by dekor »
check on youtube.
I put a small movie there.
Try this link:
http://www.youtube.com/watch?v=0eCEmIaYRQA
dekor.
hand_drake
Hi dekor, thank you for the answer, but I have difficulty using that LG com spy.
My connection is using USB <-> Logo!. When I running LG com spy, i have rearrange the USB converter to Com1, but the LG com spy cannot connect to Com1.
What connection do you use? Are you using USB to Logo converter also?
lethevinh
Post by lethevinh »
How can you crack software simens logo, :oops: please post them for everyone to share possible? Thanks! :D
hand_drake
What are doing here 'man. You replying with non regarding question. Why don't you creat your own topic!!! :evil:
dekor
Post by dekor »
Dear friend,
I use on two different situations:
1. using physical port COM1
and
2. using an adapter from USB to RS232.
After that I use RS232-LOGO cable. The movie is made using that combination.
I never experienced the USB-LOGO cable.
I read somewhere on web about other USB sniffer ...
Please check and share with us your experience.
dekor
hand_drake
Hi dekor, after finding way to unlock Logo password. I found the way!
The tricks is similar to your methode, but the problem is how to get to COM1? As I only have USB?
The converter is COM3.
And so:
1. Create VM Ware 7.0 with XP SP3 machine.
2. Copy all that necessary program to open the password. (LG Com Spy and Logo Soft Comfort 6.1)
3. Install driver for USB (still in virtual)
4. Turn off the Virtual PC. And setting the connection; my USB port become COM3 in my physical PC but I configure COM1 in Virtual PC.
5. Turn on the Virtual PC. And try the methode of your.
6. "tada'"....the password will shows up exactly as you are using the RS232 to Logo. (clap)
7. Do as you like what you want to do with the program. 8)
hand_drake
dekor
Post by dekor »
I am happy to hear that you solve your problem.
Have you checked to use LGcommSpy without virtual machine, but selecting from options / startup Com 3 as your USB adapter is set?
Please try and that way and tell us if it is a simplest way or we must follow your method.
dekor
hand_drake
Re: [?+]: How to crack the password for a LOGO plc?
I have try for many many times, that else than 'pure' RS232 cannot be monitored, not even only monitor but cannot configured.
Just like the dead button that you cannot click.
I think there is no easiest way else than using your method but also using pure RS232 to connect to LOGO.
That's what I can conclude.
arazov
Post by arazov »
dekor wrote:Hi,
check on youtube.
Try this link:
dekor.
It works! Thank you!
tufail_74
Post by tufail_74 »
Hi friends,
I too have the same problem. I have USB cable and it was on COM7 but i changed via DEVICE MANAGER to COM1 as that is free in my PG. But when i run the LGCOMSPY, i dont see button active to select COM port. None of them is active.
Can anyone plese help me?
dekor
Post by dekor »
have you try an USB trafic monitor ?
Try to Use soft Bus Hound.
Have a look here
viewtopic.php?f=14&t=14390
Let us know your results.
dekor
gycu
Post by gycu »
Hello all,
It's my first post here, it's a great forum.
Just wanted to say thanks to Dekor, I used his tutorial uploaded 2 youtube and found the logo password.
I used "free serial port monitor" (only for 32-bit systems), an usb logo cable. On my first attempt, the logo soft confort 6 crashed, but the second time worked and showed me the password.
Cheers mates
dekor
Post by dekor »
Hi to all,
please see same video's on new links:
http://www.youtube.com/watch?v=XPl7OFyH2Mc - for serial adapter
and
http://www.youtube.com/watch?v=5yblVgSESLo - for USB adapter.
and
http://www.youtube.com/watch?v=666os0X2s5M - for 0BA7 ethernet connection.
dekor.
naserkargar
Post by naserkargar »
Hi dekor
please provide download link for movies , in my country not possible access to YOUTUBE site !
garg_mm
Post by garg_mm »
Thanks Dekor. I have recovered password from Logo by using the method you described. (tyou) (gpost) 8)
dekor
Post by dekor »
I am happy to hear that.
Spread the information!
dekor.
pilotpent
Post by pilotpent »
Hi !!
I've got a problem with the new version of logosoft (V7.1.5) and a 0AB6 module.
I can view the password of the old ones, but with this module the password is "coded".
My password in hexa is C4 DE C7 DF D8 wich is not ASCII standard caracters.
Somebody have the solution ?
kirolos nabil
Post by kirolos nabil »
hi i have aproblem in logging fatek plc as i dont know the password but i used the free serial port and by using the console view i get along code but i still dont know how could i extract the correct password from it and this is the code:
0102041C0070094012A0145A0010000041C007000160000000453040830000431404F00082346DC00013BE578
could you help me please?
Raptor
Post by Raptor »
Please share LGComspy software..
asteroidehk
Post by asteroidehk »
Hello Friends
I have tried with Logosoft 8 and free serial port monitor, also with LGComSpy but the response is strange characters. The module is an 0BA6
Also I have tried with Logosoft 6.1 and 7.0.30, but I can not connect because the module requires a newer version.
Somebody could help me?
Thanks in advance :mrgreen:
nldutchmen
Post by nldutchmen »
Hello Dekor,
I am having issues to get the password from the Logo plc. The plc i am having issues with is 6ED1 052-1MD00-0BA6. I am using Logo soft 8.
Can you help me out please.
dekor
Post by dekor »
what cable you use? USB or serial?
Let me know.
dekor
vjalalian2
Post by vjalalian2 »
hi.I try read password logo but password is ÜÌÜÊÈ. this password not standard characters.
plaese help me for password
dekor
Post by dekor »
What version of BM you have?
It is english language of your operating system?
Also for application?
mohdabshr
Post by mohdabshr »
Hi ziconltai
could you please upload Crack Logo 0AB6 again because link is dead.
thanks,
daro31ie
Post by daro31ie »
Hi
I same try read password logo but password is like ÜÌÜÊÈ.
My plc is LOGO OBA6.
Any solution?
daro31ie
Post by daro31ie »
Does anyone have any solution with this password encoding?
Best regards
Daro (close)
pozabi
Post by pozabi »
Works fine with USB kabel and HHD Software Device Monitoring Studio.
BR
caspyro
Post by caspyro »
hi can any one share the LGComspy software?
thanks in advance
Mad MAX
Post by Mad MAX »
Good day everybody!
Any chanse to share LGCommSpy++ exe one more time? The link above is dead
Servini
Post by Servini »
Still no ideas about encoding passwrds for LOGO 8?
My answer through COM-port was C9 C2 D3 DE C9
ЙВУЮЙ in Windows 1251 CP.
I cannot find any solution.
dekor
Post by dekor »
I saw a short movie on Youtube.
Seems that this is possible up to LOGO v 8.3.
Check the movie and let us know your experience.
https://www.youtube.com/watch?v=TpH4EABGYCs
rkmiecik
Post by rkmiecik »
Try this video
[dead]
vvvasiliss
Post by vvvasiliss »
The video is missing (h) !!! Pls upload to Rumble or Vimeo. Thank you !!
ghulamshoaib
Post by ghulamshoaib »
hello Everyone
I am using LGCOMSpy++ for decoding LOGO plc password but the result is not the ASCII letter
last line showing 4E 54 45 4E 52 4F 54 5A 00 47. can anyone help me how to find the password?
waiting
Shoaib
gyppss
Post by gyppss »
sjoerdnld
Post by sjoerdnld »
I sniffed the serial comm on 0BA6 module, but password is unreadable using hex to ascii converter.
The serial packets:
2106032145551717AA06420100FF474000060200FF1F00060300FF1F00040200FF1F01060300FF1F01000200FF48FF060300FF48FF40050600000566000AC0D9D3CED2D7CD9200005E
Anybody know how to decypher?
I also have the serial flash readout, but really a lot of data.
dekor
Post by dekor »
Can you tell us what version of Logosoft you use?
sjoerdnld
Post by sjoerdnld »
I tried 7.1.6, 8.0 and 8.3, they yield the same code.
Also I read both flashes on pcb, one has texts used in the software, 2nd unreadable program.
sjoerdnld
Post by sjoerdnld »
Any clue how to interpret?
hex to ascii from address 05 66 makes: ÙÓÎÒ×Í which unreadble same to above.
05 66 00 0A length10: C0 D9 D3 CE D2 D7 CD 92 00 00 5E
Usaid Asad
Post by Usaid Asad »
hi fellows..
i retreive a password ÊÃÄÎÔ.....× can anyone can convert in english alphanets. Plz guide..
Thanks in advance.
Rex2701
Post by Rex2701 »
It looks like cyrillic letters without having right codepage. Like you have no cp1251 but cp1252 only.
