PLCSim Profibus/Profinet communication example
bjekas
Post by bjekas »
Hello yall,
First of all Im kinda noob to communications with Siemens PLCs...
Im trying to simulate communications between 2 cpus (s7-300 for example) and I was told that it is possible using PLCSim 5.4 Sp3 HF1...
But every test I did whent bust... Using CPs, using CPs integrated with the CPUs... Every try I did went wrong one way or another... (h)
Does anyone have a simple program with hw configured and can send me pls pls pls...
Or maybe a doc where it explains how to configure a 2 cpu communication using profibus/profinet that can be simulated using plcsim?
Thanks in advance
Info
Faq & Info
Faq & Info
Re: PLCSim Profibus/Profinet communication example
Post by Info »
bjekas
Post by bjekas »
First of all thanks for the quick reply
I tried your example and it doesn't work...
Im getting Status Com = 16#0001 on both cpus dont know why!
I tried an similar example but using PROFIBUS and got SF on both cpus... (boom)
bjekas wrote:I tried your example and it doesn't work...
1. Example tested and work.
2. Which Step7 version you use ?
bjekas
Post by bjekas »
Im using Step7 5.5
today I have tested Simatic example S7_PLCSIM_CPU_Communication.zip
It work. Step7 5.5
German - International
Z=C (countig from 0 while C1<999)
EB=IB (enable conting)
AW=QW (LED output show)
FAQ wrote:In the "S7-PLCSIMN" listbox dialog, you select the configured interface "PLCSIM (TCP/IP)" (for this example)
You must select the instance "S7-PLCSIMN" (1 or 2) before loading program to PLCN (1 or 2).
