Hello!!!
Can anyone explain me what it means the following text on the panel. The ABB ACS800 converter, then power is on, on the panel appears the
"CDP312 PANEL V5.2"
and no change, show only this text, forever. Im don't know what is it means. May be somebody know???
Thank's.
Pavel.
[?]: ABB ACS800 converter Start up delay.
Pavel_74
SOULHACK
Re: [?]: ABB ACS800 converter Start up delay.
I see this problem one time, when you switch the mains supply for a long time and you power on the drive it's works fine.
I replace the RMIO CARD and I solve this problem, check the revision "J" is the better.
Regards SoulHack
Regards SoulHack
Pavel_74
Thank's you.
I will try to find new RMIO board.
Pavel
Pavel
