hello to all
i have schneider Drive ATV 71drive
normaly if you remove the drive control panel ( LCD-HMI) for any reson the drive trip, i like to keep the drive runing if i remove the control panel like other dirive i use it any one know the parameters to do this function.
thanks in advance
[?]: schneider Drive ATV71: if you remove the drive control
azamo12
nguyenhonghao
Re: [?]: schneider Drive ATV 71
You can only remove drive control panel that drive is not tripped if you don't select command source and reference source from drive control panel
Best regards.
Best regards.
azamo12
