[?]: How to use "Copy" to move siemens license?
a151218
Post by a151218 »
Now I can use Sim_EKB_Install to setup siemens license to computer...
I can use "cut" to move license,But can't use "copy" to move license...
Is there any method to copy siemens license to another computer without use Sim_EKB_Install ? (oo) (oo) (oo)
Re: [?]: How to use "Copy" to move siemens license?
No.
ALM can only "MOVE"
EKB_Install can only "Install" (but you can to install key direct to USB flash)
sanruku
Post by sanruku »
The licenses are in a hidden folder "AX NF ZZ".
Just copy them to the computer you want.
sanruku wrote:The licenses are in a hidden folder "AX NF ZZ".
:anon: "Just"<>just
"Just copied" key is not valid.
But you can send me "Just copied" new keys for new release 2011.
tepisjrf
Post by tepisjrf »
i have use an utility.
1. transfer the key to an usb pendrive.
2. with the software USBimage tool create an image from the usb pendrive and save it in your pc.
3. with the usbimage tool , now you record in all the pendrvies that you want the license that you already tranfered in your first pendrive.
regards.
