Hi. Is posible to change the horizontal position of the contactors list that appears below a Booster coil?.
Because I dont have space below the Booster coil. Another solution is to make another Booster coil and reference it, but when I try this last one, the contacts list again appears below the new Coil ( http://imagebin.org/137008 ).
Thanks.
Eplan Coil
dsekulic
Re: Eplan Coil
Open eplan. Right click on coil and than select Properties. Go to Display tab. In lower right corner of this tab You have Contact Image: Press ... button placed right from Contact Image. Deselect Automatically aligned and specify X and Y position of contact image.
regards
regards
scarebyte
Re: Eplan Coil
Thanks it worked. And exist an option for put above the contac image an indentifier, so that it refers to the coil.dsekulic wrote:Hi,
regards
Regards.
dsekulic
Re: Eplan Coil
Double click on coil. Go to Display tab. Press New icon and choose Device Tag (superior, without project structures). Press OK. Afterward, go with mouse over this new property and right click on mouse. Select Text -> Move property text and then drag this property above contact image.
regards
regards
scarebyte
Re: Eplan Coil
Hi, thanks it worked. Btw, you know if exist something like "copy format" for settings properties. So i can copy the properties settings such as color, size, invisible, position ,etc from one entity(resistor, coil, etc) to another.
Regards
Regards
dsekulic
Re: Eplan Coil
Yes it is possible. Select Your good formated coil. Press Edit -> Copy Format. Then select coil which You want to modify. Press Edit -> Assign Format. That's all. By the way probably You have icon for format copying on Your toolbar.
regards
regards
scarebyte
Re: Eplan Coil
Ok thanks, I didnt know copy format worked also for copying properties settings. Btw, when creating cable definitions, it is created in one postion only along the wire, so I can numerate only in that position which is generally at the start. Is posible to numerate also the endings(http://imagepaste.nullnetwork.net/viewimage.php?id=1795)?. I think I could if I can create a cable definition with the same IME at the end, but thats the correct way?.
Regards
Regards
majzdor
Re: Eplan Coil
Also you can click on symbol to mark it, and with Ctrl+B drag and drop any of displayed properties including contact tree.
