i search for ABB 800xA PG2 sample displays or tutorials
with afw files.
Regards, nola2k
[?]: ABB 800xA PG2 Samples displays or tutorials
Re: [?]: ABB 800xA PG2 Samples displays or tutorials
Hello, nola2k
I have an 800xA demo project (afw file).
As far as I remember there are many PG2 displays used.
If you interesting I can upload it to you.
For that .afw your 800xA require:
800xA Core SV5.0.2 with Rollup 1f or better
800xA Process Graphics 2
800xA PNSM 5.0 SP2 RU1
800xA Asset Optimisation 5.0 SP2 RU1
Hello, Linkinx64
i'm very interested.
Please upload.
Many Thanks.
nola2k
Please upload.
Many Thanks.
nola2k
Hello Linkinx64,
I am using the ABB 800xA 5.0 SP2 VMware Clone you uploaded sometime ago and I and have some problem with building Graphics of the Objects I add in the Function Structure. Whenever I click the Edit button in the Workplace and the VB Professional is about to open, I receive this error message - Invalid License for GraphicsBuilder tool (0X4ABF0). What is the cause of such error and how can I resolve the issue.
Please, kindly help.
Abelky98
Abelky98
Hi, Abelky98
I'm not so clear which VMware clone I uploaded.
As far as I remember I've uploaded only SV4.1 image here: viewtopic.php?f=3&t=12397 but that is Virtual PC image.
However, you can open .sla file and check for the follow entries under 800xA Engineering section:
ENG_GRAPH_BLDR
ENG_GRAPH_BLDR_PG2
If one of those missing you'll get an error message while opening Graphic/Generic Element/Display PG2 for edit.
Use bypass in this case. Starting from bypass for CLS v5.0.2/2 these features are included in license file (sla).
Linkinx64
ENG_GRAPH_BLDR
ENG_GRAPH_BLDR_PG2
Linkinx64
Hello Linkix64,
Sorry, it might be another person who uploaded. But when I check the Engineering section in License Entry, I see ENG_GRAPH_BLDR
ENG_GRAPH_BLDR_PG2 and they are for version 5.0 and each has 10 as QTY. Could you please, upload CLS Bypass for 5.0.2/2 so that I can try it. And I will be grateful if you would kindly offer more ideas towards providing me a solution.
Thank you for your kind and useful responses
Abelky98
Abelky98
Hi Linkinx64,
Please, upload CLS Bypass for ABB 800xA 5.0.2/0, 5.0.2/2, 5.0.2/3 and 5.0.2/4. The CLS Extension is 5.0.2/3 and all the Graphics Extensions are 5.0.2/0 and my 800xA Base is 5.0.0 Build 5.0.2.4.x.x. I also need further advice.
Thank you for all your help!
Abelky98
Abelky98
All bypasses already uploaded:Abelky98 wrote:Please, upload CLS Bypass for ABB 800xA 5.0.2/0, 5.0.2/2, 5.0.2/3 and 5.0.2/4.
For CLS 5.0.2/0 and CLS 5.0.2/3 see this topic: viewtopic.php?f=3&t=12397 Do not recommend to use CLS 5.0.2/3 separately from 800xA rev.D. (SV 5.0.2/4)
For CLS 5.0.2/2 see this topic: viewtopic.php?f=46&t=13517 under "du hast" keyword. Changes date in .sla - license deadline (April, 30, 2011) coming soon.
CLS 5.0.2/1 - I don't have this version.
CLS 5.0.2/4 - Up to date not yet released.
You can try (re)install rev.D and use bupass for CLS 5.0.2/3.Abelky98 wrote:Whenever I click the Edit button in the Workplace and the VB Professional is about to open, I receive this error message - Invalid License for GraphicsBuilder tool (0X4ABF0).
Actually, VB is out of date. Use Process Graphics 2 instead.
regards, Linkinx64
Hello Linkinx64,
Thank you very much! I reinstalled 800xA rev.D. (SV 5.0.2/4) and applied the CLS and the problem is solved
Thanks for all your help!
Abelky98
Abelky98
