Is this a joke from Siemens?
If you use block privacy to protect your code, the block can not be transferred to the PLC.
A strange error related to the local data appears, and the PLC does not accept the encrypted block.
The idea is to leave the PLC program to the customer as a backup but with the protected blocks.
If the blocks can not be transferred, what is this useful for?
Or else we face another demonstration of the know-how of Siemens software programmers?
[?]: Block privacy blocks PLC transfers?
Scarch
Re: [?]: Block privacy blocks PLC transfers?
Block privacy options work only with NEW CPU 2011 (need new firmware V3.2).
Scarch
The PLC is new (2011) (314-C-2DP with 2.66 firmware), all functions to encrypt the blocks work, but they can not be transferred to PLC.
This is OLD CPU with OLD firmware and hardwareThe PLC is new (2011) (314-C-2DP with 2.66 firmware), all functions to encrypt the blocks work, but they can not be transferred to PLC.
http://support.automation.siemens.com/W ... n/12019198
New is 6ES7314-6EH04-0AB0 CPU314C-2PN/DP (Delivery release 2011-02-04) with v3.2
http://support.automation.siemens.com/W ... n/48214199
Encryption of blocks Yes; using S7-Block Privacy
http://support.automation.siemens.com/W ... n/46119963
Firmware V3.2 with new functions
Other new functions
* Enhanced HMI communication performance by parameterization in HW Config
* Improved know-how protection for FBs and FCs with S7-Block Privacy
How do you install the improved block protection for FBs and FCs in STEP 7 V5.5 onwards?
http://support.automation.siemens.com/W ... n/45632073
Only for new CPU from v3.2
Scarch
