[?]: S5 25 pin ----- 9 pin connect to pc
cemara
Post by cemara »
Dear all,
i got 6es57342bf00 (s5 tty cable 5m).
i want to connect to my pc (9 pin).
this connector has a 25 pin.
i wire:
25 pin ----- 9 pin
2        ------ 2
3        ------ 3
7        ------ 5
i got plc time out.
has anybody use this cable with 9 pin connector before? what do i miss here?
Corosop15
Re: [?]: S5 25 pin ----- 9 pin connect to pc
Post by Corosop15 »
Signal              9-pin            25-pin
Carrier Detect        1                 8
Receive Data          2                 3
Transmit Data         3                 2
Data Terminal Ready   4                20
System Ground         5                 7
Data Set Ready        6                 6
Request to Send       7                 4
Clear to Send         8                 5
Ring Indicator        9                22
dehell
Post by dehell »
I think your cable it is not good!!!
Your cable it is not a TTY cable: this cable is only for PG 7XX
http://support.automation.siemens.com/W ... aller=view
Take care do not connect your serial COM to PLC, you will destroy it!!!
Best regards.
centipede
Post by centipede »
Look here:
http://helmholz.de/
Components for S5-Interface Converters
indian
Post by indian »
cemara
Post by cemara »
dehell is right this cable is not a tty cable. it is used only with pg7xx.
i think what indian post is the cable configuration to connect pg7xx with s5 cpu.
i guess i have to find a tty cable. thank you everybody.
manus_a
Post by manus_a »
Hi cemara
I also had problem with step 5 software when I used converter USB ---> RS232 9pin ---> RS232 25pin ---> TTY ---> PLC S5
but software PG2000 it working with same converter
Try PG2000
Best regards.
