dear expert wincc
In Wincc v5.0 above , if i have data db in plc (INTEGER) , how can display iofield in format decimal .
example :
in PLC
DB10.DBW0 ==> 1512, in display wincc ===> 15.12
Thanks alot
[?]: Format Number WinCC 1512 => 15.12
Victor Yeo
PLC_ITA
Re: [?]: Format Number WinCC 1512 => 15.12
hello, you have 2 way to do this :
1 : in tag management you use a linear scaling in the tag read from the plc
2 : in I/O filed you need a dinamic windows and insert the tag / 100
bye
bye
Serge_n
You must enter 'tag/100.00'PLC_ITA wrote: 2 : in I/O filed you need a dinamic windows and insert the tag / 100
This is important for decimal readings.
PLC_ITA
Serge_n wrote:You must enter 'tag/100.00'PLC_ITA wrote: 2 : in I/O filed you need a dinamic windows and insert the tag / 100
OPPS... Thank you serge_n for your detail
