Hello to all, I have a technical problem with connecting to WinCC srver over VPN (internal function of win 2k3 PPTP or use OpenVPN software - on both).
In industrial object has a WinCC server with all function on it, some clients use same network with server and don't have any problems.
But I need connect remote client to this server over inernet for edit a project and remote visualisation.
In remote local network has a server external IP 80.x.x.x.
On this server stand a pptp server all clients connected on it gets internal ip. all packets works good (ping, samba) excepting WinCC server it told that Client is not in list of server.
I tried to use the internal DNS and WINS-servers to solve the problem, but it still does not work.
Help me who has any experience.
Thanks.
[?]: Connecting to WinCC server over VPN connection
saniyo
ziemson
Re: [?]: Connecting to WinCC server over VPN connection
Try to find file hosts on C:
Write host name with IP adress of server in this file.
Maybe it will be solve for your problem.
Bye
Bye
