Dear Friend Hi,
How we can copy application program/ configuration from a PC where WinCC is intalled .
I have PC Where Wincc 6.2 is installed and application runs on it.
From recent file menu i got location of the application / configuration folder.
But if i tried to copy it ; message comes that this folder/ file is being used by other program and can not copied.
I even stoped WinCC RT and explorer but it gives same message.
Pl tell me procedure to copy this.
Amit
[?+]: How to copy WinCC 6.2 application program
amit
peterc101
Re: [?]: How to copy WinCC 6.2 application program/configura
you need to open taskmanager and close all wincc processes running
after you will be able to copy
amit
Dear peterc101
Thank you very much. Your sol works fine.
Amit
Amit
Yury
Re: [?+]: How to copy WinCC 6.2 application program
Also you can stop SQL SERVER (Start/Programs/Microsoft SQL server 2005/configuration tools/SQL server configuration manager/SQL server 2005 Services ), copy you program, then start sql server and start WinCC project
