hi all
i want instal cp433-5dx04-0xe0 v6.5 but in library not find this version i use pcs7 6.1 and step7 5.5
[?]: i want instal cp433-5dx04-0xe0 v6.5
kambiz
Re: cp443
use v6.4
Siemens wrote:You can configure the CP 443-5 Extended (6GK7 443-5DX04-0XE0) V6.5.11
- with CP firmware version V6.4 with STEP 7 version V5.4 SP4 or higher, or
- with CP firmware version V6.3 with STEP 7 version V5.4 SP4 or higher, or
- with CP firmware version V6.1 with STEP 7 version V5.4 or higher
- with CP firmware version V6.0 with STEP 7 version V5.2 SP1 or higher.
Umencho
Re: [?]: i want instal cp433-5dx04-0xe0 v6.5
Hello,kambiz wrote:hi all
it's not recommended to do update of PCS7 software like in your case - PCS7 6.1 with Step7 5.5. Or might you meant PCS7 7.1?
Best regards,
umencho
