[?]: Can you explain what this logic means?
macroms
Post by macroms »
Help please..Can you explain what this logic means?
      L     DB10.DBW  210
      T     #conv_akku1
      TAK
      T     #conv_akku2
      L     STW
      T     #conv_stw
      L     DB10.DBB    1
      SLW   4
      LAR1
      L     #conv_stw
      T     STW
      L     #conv_akku2
      L     #conv_akku1
      T     DB10.DBW [AR1,P#0.0]
Schtiel
Re: Help on STL code..
Post by Schtiel »
What command you don't understand? See "Help on STL" in Step7
L - load to ACCU 1
T - transfer from ACCU 1
TAK - exchange the contents of ACCU 1 with the contents of ACCU 2
L STW - loads ACCU 1 with the contents of the status word
SLW - shift left word
LAR1 - load address register AR1
etc.
macroms
Re: [?]: Can you explain what this logic means?
Post by macroms »
Actually this is a converted program from S5..What do you mean by this?
1. #conv_akku1
2. #conv_akku2
3. #conv_stw
4. DB10.DBW [AR1,P#0.0]
5. Where is this status word came from?
centipede
Post by centipede »
1 to 3:
This parts are temp Variables, here the converter saves the accu1 and 2 and stw (status)
the converter always saves the accus on the beginning of an FC or FB
5: every command make changes in the stw, take a look at the manual
4: this is indirect addressing
L     DB10.DBB    1
      SLW   4
      LAR1
Here the Byte 1 from DB10 is loaded to AR1 (adress register) with slw4 you get the content to the pointerformat
  L     #conv_akku1
Here you transfer accu 1 to the word with the adress from the byte 1, you loaded before.
for example:
content from DBB1: 100
after the slw you have the pointerformat 100.0
than you transfer the content from accu1 to db10.DBW100
I hope this helps :oops:
