Hello...How can I make logical tags in WinCC Flexible 2008?
Example in Visibility I want to make Tag1 And Tag2
[?+]: make logical tags Tag1 And Tag2 in WinCC Flexible 2008
macroms
Re: [?]: make logical tags Tag1 And Tag2 in WinCC Flexible 2
S7-CPU: Tag1 And Tag2 =>Tag3
WinCC Flexible 2008: Tag3 in Visibility
macroms
Sir you mean I want to add logic in S7?
because I don't want to make like that is it possible I will put directly the tags in WinCC flexible?
dehell
Use a script if Tag1 or Tag2 data change.
In the script make Tag1 and Tag2 = Tag3 (internal panel tag)
Then use Tag3 for visibility
macroms
Sir can you tell me what is the right syntax because it gives me an error on the script..I make only like this on the script var1 And var2 = var3
dehell
macroms
Thanks..it's working.
