[LINK]: HF3 for Step7 V5.5
sventek
Post by sventek »
Here you can download Hotfix 3 (no joke) for Step7 V5.5.
95.78 + 5.75 MB
[dead] :/437760484/S ... .part1.rar
[dead] :/437760508/S ... .part2.rar
or
http://narod.ru/disk/1599271001/STEP7V5 ... 1.rar.html
http://narod.ru/disk/1599317001/STEP7V5 ... 2.rar.html
1.1 What has Changed Compared to Version STEP 7 V5.5?
HW Config
The function "Save and Compile" with activated CPU web server now runs faster.
The upload functionality of the hardware components "SCALANCE X414 V3.0" and "ET 200M" has been improved.
The download functionality of a station with CPU 400 as of V6.0 and Shared Device capable device with output module has been improved.
The compatibility with V1.0 GSDML files has been expanded.
Working with submodules via the command interface has been improved.
The frame planning with synchronized stations has been optimized.
The use of a CP1616, CP1616 onboard or a CP1604 is possible with firmware version V2.5.
When using a CP1616, CP1616 onboard or CP1604 as of firmware version V2.4, the IO device link using the IO device description of a third-party vendor is possible.
The "Edit Ethernet Node" function when using a terminal adapter has been improved.
As of this Hotfix: The assignment of process image partitions (PIP) in the PROFIBUS and PROFINET environments has been improved.
As of this Hotfix: The use of GSDML files has been optimized.
As of this Hotfix: The function "Upload to PG" has been improved for compact CPUs.
Report System Errors
Optimized creation of messages
The optimized creation of messages significantly reduces the creation time and number of message instances.
This optimization is the default setting. You can still use the old procedure by deselecting the new option "Optimized creation of messages" in the "Messages" tab of the "Report System Error" dialog box.
Note: You should always delete all blocks with the "SFM" programming language prior to generation when you change from the old procedure to the optimized creation of messages.
You delete the respective blocks either in the SIMATIC Manager or in the "Report System Error" dialog box with the "Delete" button.
Channel-specific diagnostics with an ET200SiSP has been improved.
Topology Editor
The export of statistical data has been enhanced.
The "Open" dialog box now offers project selection.
The visual representation now includes an automatic update.
The display and handling of modules in the Topology editor and in the Web server has been improved.
As of this Hotfix: The configuration of passive components has been improved.
Configuring Messages
When creating a project, there is no longer a prompt to ask whether messages should be created for the entire project or for the entire CPU. The new default setting is assignment of the message numbers for the entire CPU (without a prompt).
S7-Web2PLC
As of this Hotfix: An improved version of this application is supplied.
NCM
As of this Hotfix: The configuration of S7-300 connections for configured message texts and source information from the OPC Alarms and Events Server has been improved.
SIMATIC Manager
As of this Hotfix: The function "Compare blocks" with the option "Including SDBs" has been improved.
sventek
