[?+]: How to install SETP7 V5.5 to non-default directory?
xdoit
Post by xdoit »
Hi everybody,
I want to change the default installation directory to disk D instead of disk C as in Windows7, but i can not find out a option to change that when running setup. :(
Can anybody give me a solution?
Thanks in advance.
Re: [?]: How to install SETP7 V5.5 to non-default directory?
if i remember:press next,before install prosedure you can change destination folder
Schtiel
Post by Schtiel »
As I remeber, if you are installing Step7 5.5 over older version (i.e., Step7 5.4), it will not let you to change installation directory.
sanruku
Post by sanruku »
(Never tried this, just an idea)
Well, most of us remember this: http://xuek.ru/eblog/2009/10/step7-at-win7/
(Russian http://xuek.ru/blog/ )
where it was modifying the msi installer in order for Step7 v5.4 to install to Windows7.
So, what if there is a way to modify the default install location that way?
(or even better, make the program ask the user on install time...)
glhf
xdoit
Post by xdoit »
Many thanks to sania, schtiel and sanruku.
Yes, I can change the target directory before step7 5.5 starting installation. (pgood)
http://www.dumpt.com/img/links.php?file ... 37i0mh.png
