[LINK]: Ecabinet v2.0
toos tablo
Hi
Does any have Ecabinet version 2.0 with crack?
Re: Request: Ecabinet v2.0
I also want to use Eplan cabinet 2.0 too. I had EPLAN P8 2.0, Rittal RiCAD 3D 2.2 but without Eplan cabinet 2.0, you can't use all of them perfectly. Pls share Eplan cabinet 2.0 with cr@ck
Can You pls share RiCAD 3D 2.2?
Thanks and best regards,
Link
- Forum Community
- Location: We are anonymous users. We do not read your private messages :( Ask questions in the forum !
- Contact:
Version: 2.0.5.4291
Creator: http://www.eplan.de
Interface: Multilingual
OS: Window XP / Vista / Seven
http://depositfiles.com/files/umjnsde4t
[dead] :/442397779/epca20.part1.rar
[dead] :/442397783/epca20.part2.rar
[dead] :/442397780/epca20.part3.rar
[dead] :/442399539/epca20.part4.rar
or Torrent
http://rutracker.org/forum/viewtopic.php?t=3365517
sm
Version: 2.0.5.4291
or Torrent
sm
Problems with using P8 and Cabinet
First install Cabinet, after P8
Run dongle-emulator for Cabinet
and after dongle-emulator for P8
Насколько я понял у P8, выложенного ранее, и этого Cabinet разные файлы лицензий, не перекрывающие друг друга.
Поэтому приходится при старте P8 запускать его донгл эмулятор с файлом лицензии, а для кабинета - свой.
Во всяком случае у меня так работает. Но жутко неудобно.
Ставил сначала Cabinet, потом Р8.
Re: [LINK]: Ecabinet v2.0
At last!
Thank you vmch!
Al running with one serial,one dongle!
Thank you vmch!
ahmedsaidm
It didn't work with me. only one at a time. if you start the dongle emulator service of cabinet you will not be able to start electric. and if you stop dongle emulator service you can use electric only.
kindly help me on this.
Try to remove all dongle from .../Document and Settings/All User/Application Data/Eplan/Common/...,and install only new Emulator.
ahmedsaidm
when i do this cabinet is now working but electric send me a message "no license" .if press setup.bat it will stop hasap service in turn the cabinet will send "no license".
so i can't start both of cabinet and electric in the same time.
try to run both in your pc in the same time you will find that you can't.
Have the same problem, this Soft whats start first ist working and the other have probleme with licence.
Its not possible to start both at the same time!
Does some one have a soulution?
But anyhow, thans for the work
My contents on C:\Documents and Settings\All Users\Application Data\EPLAN\Common:
SN-U10066-New serial from chinez frend
SN-0VEW-serial for VEW
SN-00CPM-serial for CPM
SETUP-EXE MS-DOS
MYLOCK.FST
hardlock-System file for HASP
With that configuration in my System with XP-Professional all(!!!) "Eplan" run together
SETUP-EXE MS-DOS
MYLOCK.FST
Can you provide this files?
So we can test under XP.
How about this Files now?zart wrote:My contents on C:\Documents and Settings\All Users\Application Data\EPLAN\Common:
SETUP-EXE MS-DOS
MYLOCK.FST
Wher we can get SN-0VEW-serial for VEW and SN-00CPM-serial for CPM, to get Cabinet working?
Every time i open Eplan Cabinet it asks me t oinstal BDE 5.11. What does it mean and is it important for something. How to fix this it is a bit annoying!
Thanx to everybody here!
