[?]: STL Code mitsubishi =>Siemens
Jason5575
Post by Jason5575 »
Dear Colleagues,
I had a function from mitsubishi PLC , now i am working on converting to siemens PLC.
There is a function in mitsubishi PLC , i can't figure it out when convert to siemens :? i not STL expert
so I hope any STL expert here can help me on this .
Below are the explanation,
Call Function;
DB100.DBB0 - MOVE TO DB200.DBW0 ( Lo BYTE )
DB100.DBB1 - MOVE TO DB200.DBW2 ( Lo BYTE )
DB100.DBB2 - MOVE TO DB200.DBW4 ( Lo BYTE )
Up To
DB100.DBB429 - Move To DB200.DBW....
If i using L and T command i need to repeat 430 times. :cry:
Thank you very much in advance.
Jason Law
Re: Siemens STL Code
try this,not checked (no)
FCxx
     OPN DB100
     OPN DI200
     L 430
lop1:T MW0 //WORD FOR LOOP
     L 1
     -I
     SLW 3
     T #Nr_BYTE //temp var of the FC(FORMAT DINT)
     SLW 1
     T #Nr_WORD //temp var of the FC(FORMAT DINT)
     L DBB[#Nr_BYTE]
     T DIW[#Nr_WORD]
     L MW0
     LOOP lop1
sobanski
Post by sobanski »
Hallo
You can use sfc 20 to move a pointer area to another, this function copy all variables in one area and put in another, just like bellow:
CALL "BLKKMOV"
SRCBLK :=P#DB100.DBX 0.0 BYTE 430
RET_VAL:=DB100.DBW440
DSTBLK :=P#DB200.DBX 0.0 BYTE 430
I hope that`s it help you
see ya
sfc20 copy byte to byte,he need byte to word
lx0520
Re: [?]: STL Code mitsubishi =>Siemens
Post by lx0520 »
Try this:
FC**://
           L     P#DBX 0.0
           T     MD     2
           L     P#DBX 0.0
           T     MD     6
           L     430
NEXT:  T     MW    10
          OPN   DB   100
          L     DBB [MD 2]
          OPN   DB   200
          T     DBB [MD 6]
          L     P#DBX 1.0
          L     MD     2
          +D
          T     MD     2
          L     P#DBX 2.0
          L     MD     6
          +D
          T     MD     6
          L     MW    10
          LOOP  NEXT
enjoy!! :D :D
For s7 data format, the DB200.DBW0 = DB200.DBB0(high byte)+DB200.DBB1(low byte), above code moved byte to word format but byte data length only, for example: move DB100.DBB0 to DB200.DBB0, IF you want to move data to low byte, Just modify code:
T DBB [MD 6] ==> T DBW[MD6]
enough!!
xdoit
Post by xdoit »
SIEMENS PLC can only open one DB and one DI in the same time.
lx0520
Post by lx0520 »
sania wrote:try this,not checked (no)
FCxx
     OPN DB100
     OPN DI200
     L 430
     L 1        [color=#FF0000]// here, no update indirect address pointer of loop cycle.[/color]
     -I         [color=#FF0000]// so, just move DB100.DBB0 to DI200.DBW0 with 430 times.[/color]
     SLW 3
     SLW 1
     L DBB[#Nr_BYTE]
     T DIW[#Nr_WORD]
     L MW0
     LOOP lop1
you are not right it`s yes update from loop MW ! 8)
lx0520
Post by lx0520 »
Hi ! Sania
You are right! I forget the loop counter is decrease 1 of every loop cycle.
Jason5575
Post by Jason5575 »
Hi all ,
thank you so much for helping. The loop function is work perfectly.
(pgood)
Jason5575
? mitsubishi ---> siemens byte to word function
Post by Jason5575 »
Dear Colleagues,
There is a function in mitsubishi PLC , i can't figure it out when convert to siemens i not STL expert
Call Function; ignore the source Hi byte and starting address can define as pointer ??
DB100.DBB0 - MOVE TO DB200.DBB0 ( Lo BYTE )
DB100.DBB2 - MOVE TO DB200.DBB1 ( Hi BYTE )
DB100.DBB4 - MOVE TO DB200.DBB2 ( Lo BYTE )
DB100.DBB6 - MOVE TO DB200.DBB3 ( Hi BYTE )
DB100.DBB8 - MOVE TO DB200.DBB4 ( Lo BYTE )
DB100.DBB10 - MOVE TO DB200.DBW5 ( Hi BYTE )
Up To
DB100.DBB???Move To DB200.DBB....
Jason Law
FCxx
     OPN DB100
     OPN DI200
     L 430
     L 1
     -I
     SLW 3
     SLW 1
     L DBB[#Nr_WORD]                   //changed
     T DIB[#Nr_BYTE]                   //changed
     L MW0
     LOOP lop1
