[?+]: Step7/PCS7 setting for new project (download button)
maxsangar
Post by maxsangar »
Hi All
Some body know what is the reason about my Step 7 5.5 Is working but the download bottom is not available like the past version 5.4? If I open a block is always not available?
I will appreciate very much.
Regards.
Maxsangar (pgood)
Info
Faq & Info
Faq & Info
Re: [LINK]: Step7 Professional 2010 (Full) with Step7 v5.5
Post by Info »
go to name of project in left panel -> properties -> change from pcs7 to step7 -> ok -> open your blocks,download button - active
maxsangar
Post by maxsangar »
Hi
Now is working correct... You are my best. Thanks a lot!
Have a good one!
Maxsangar (pgood)
maxsangar
Post by maxsangar »
Hi All
About my post before, How can I predertermine Step 7? Because every time that I open the Step 7, my project change automaticly to PCS 7. Or How Can I erase this option about PCS 7? I don´t need it more. I must unistall and Install again? Help!
Regards
Maxsangar (pgood)
Umencho
Post by Umencho »
This settings is valid only for current project. If you open another project there should be change again. (f) :roll: And If I remembered right this behavior happens if you make installation from PSC7 disk.
Best regards,
Umencho
maxsangar
Re: [?+]: Step7/PCS7 setting for new project (download butto
Post by maxsangar »
Thank you Umencho for you information, I gonna try to Unistall and Install Again the Step 7, thats right, I install a CFC program from a PCS7 DVD... I must look if I can install the Step 7 with CFC for Step 7.
Regards
maxsangar (pgood)
