Where Can i Find National Instruments OPC server??
[reLink]: National Instruments OPC server
enrique_gf
Linkinx64
mmohamed15
Re: [reLink]: National Instruments OPC server
it is the same as KEPWare Server use it instead
enrique_gf
Is Kepware free?
mmohamed15
no Kepware is not free but you can download the key generator for all Kepware channels from here and enjoy using them check the following link
viewtopic.php?f=3&t=4694&p=6820&hilit=kepware#p6820
good luck
good luck
enrique_gf
What driver should I use to watch variables from a Labview program?
is there no beckhoff twincat driver on kepware?
mmohamed15
you can check the list of the available drivers on www.kepware.com and as much as no there is a driver for Beckhoff TwinCAT I/O
