[?]: CP1H X CONTROL STEP MOTOR
CX-One, CX programmer, NTST, Syswin ....
daiphongsk
Post by daiphongsk »
I have CPU CP1H X, GMD 04 drives (RTA) for control step motor.
Can you tell me how can do it.
i have tried with PULS, SPED or ACC , the motor run slowly at 2600 fulse frequecyand i increase fulse frequecy so it did not run
This is my programme http://www.mediafire.com/?cwfrn7p9koer7r2
thanks a lot!
rogeron
Re: [?]: CP1H X CONTROL STEP MOTOR
Post by rogeron »
To get started in your program you did not provide for indexing cycle and the API parameters are the speed to zero.
I advise you to use the function block for typical use, it is very well documented in the help.
