There are some new products developed by our company,
1, S7-200 Ethernet/Internet adapter, Connect the PG port of S7-200 to Ethernet/Internet, Cheap and good
2,S7-300/400 Ethernet/internet adapter, Connect the PG port of S7-300/400 to Ethernet/Internet, Cheap and good
3,CP5512 Express card, Now many notebook computer only have Express card slot. We develop this type of CP5512 Express card for it. Siemens don't have such product. PCMCIA is history....
4,New RS232/USB adapter V6.0 for MPI,PPI,Profibus, 100% function as SIEMENS'
5,MITSUBISHI FX PLC Ethernet/Internet adapter, Connect the PG port of FX PLC to Ethernet/Internet, Cheap and good
anybody interest in it?
www.cable-online.cn
Please send email to me for detail information: sensoroem@gmail.com
[INFO]: S7-200,300,400 to Ethernet,CP5512 Express card
Tiny
dsekulic
Re: New adapter!S7-200,300,400 to Ethernet,CP5512 Express ca
According to number 3 You have Siemens solution: CP5711. For point 1 and 2 it is not clear which port of PLC will connect to?
regards
regards
pigroplc
Re: [INFO]: S7-200,300,400 to Ethernet,CP5512 Express card
I was forced to change my laptop and now I have to search for a solution to interface with MPI and Profibus network.
I need to use VM and I would like to find a solution to use again my old CP5512.
I also take a look at this: http://www.cable-online.cn/cp5512-expre ... p-365.html
but the limit is the expresscard is not available for VM.
It seems that I have to point to the CP5517 or compatible or the following one:
http://www.hilscher.com/products_detail ... 2ac0e&bs=8
and both of the way seems to be very expansive.
Is there anybody find out some like an adapter from USB to PCMCIA suitable for my CP5512 or similar?
best regards
pigroplc
best regards
pigroplc
dsekulic
Hi ,
Take a look on Duel system adapter (http://www.duel-systemsadapters.com/dow ... on_1.0.pdf).
This is Expres Card to PCMCIA adapter.
Also You have PC Adataprer form Siemens.
Price is 300EUR. http://support.automation.siemens.com/W ... n/14692974
regards
regards
pigroplc
Thank you for your fast reply at first,
the issue I can figure is that the express card converter seems no more available and also there is no way to recognize with a virtual machine.
Also the Siemens adapter you mentioned has limits: I have the old project with the Profibus network speed setup to 12Mb and the adapter is limited to 1500Kb.
The connection problem is only for the service engineer related to the old project because the new equipment has always the lan interface.
As you can see the solution seems to be hard to find.
pigroplc
pigroplc
Son of Wodan
475,-- USD for a chinese fake?
Siemens sells the PC Adapter USB A2 for 350,-- €
user Jul 07, 2011 wrote:....
Effective October 01, 2014 the SOFTNET PROFIBUS adapter PCMCIA CP 5512 will be set to phase outSon of Wodan wrote:475,-- USD for a chinese fake?
http://support.automation.siemens.com/W ... n/22611503
