I am a beginner, I would ask if there is any trick to use a normal memory card with CPU S7 1200.
[?-]: Standard (photo) Memory card and S7 1200 ?
baltimora
fufu
Re: [?]: Standard (photo) Memory card and S7 1200 ?
Hello, has anybody found out some solution ?
Does anybody have an image of Simatic 24MB SD card ?
Thanks..
Thanks..
theedoek
Does not work. Every memory card has some sectors (usually the first ones) which contain a vendor code of the vendor who made the card.
If that code does not say "Siemens" your device will not accept the card.
These sectors are only writable once, and written during the process of producing the chip.
bublikator
Re: [?-]: Standard (photo) Memory card and S7 1200 ?
Does memory card for S7-300 work with S7-1200?
Info
- Faq & Info
Nobublikator wrote:Does memory card for S7-300 work with S7-1200?
card for S7-300 http://support.automation.siemens.com/W ... n/19102565
is incompatible with S7-1200 http://support.automation.siemens.com/W ... n/48845204
