Hi ,
I tried to install eplan P8 in my laptop with vista operating system, but it fails. Please tell me is it possible to install eplan in vista or not? If yes then how to install it? does it requires emulator or something? please help me .
Thank you.
[?]: eplan in windows vista
Linkinx64
Re: [?]: eplan in windows vista
2 years ago I used ePlan v5.75 in Windows Vista 64bit - install success and works properly. The difference (with Windows XP) was in crack files location.
ePlan P8 should install & work also properly because it is newer. And you should describe problem details (with applied screenshots if possible), not just "it fails".
devmania
When i try to install eplan, it is taking a long time about an hour. After that also it not getting installed but a pop up shows some problem regarding .Net
niila
hi i m using also vista and i installed it successfully there was no such a problem i think you check out whether installed java and.net framework softwares on your pc
Linkinx64
To reduce installation time turn system protection service, antivirus (if present) and windows defender (if enabled) off.devmania wrote:it is taking a long time about an hour
Download and install .NET framework 3.5 with SP1 and latest updates from MS website.devmania wrote:After that also it not getting installed but a pop up shows some problem regarding .Net
