DEAR ALL
I WANT TO SHARE A WINCC PROJECT MONITORING WITH OTHER USER.
SOME BODY TOLD TO USE OPC SERVER BUILT IN WINCC.cAN ANYBODY HELP ME HOW CAN I SET THIS SERVER FOR MONITORING OF PROJECT RUNING WITH WINCC v6.2 AND S7-313C CPU
[?]: OPC SERVER AND WINCC
VINESH KUMAR
zxcslo
Re: OPC SERVER AND WINCC
There is nothing to set. When runtime of WinCC is running, the WinCC OPC server is available on network.
If you browse OPC servers from your client, you will see WinCC OPC server.
WinCC OPC server only make all tags inside the WinCC available to other clients. You can not share the project, only the tags inside WinCC.
Regards
Regards
manus_a
Re: [?]: OPC SERVER AND WINCC
Hi VINESH KUMAR
If you want to monitoring WinCC project .
You can set one WinCC to server with WinCC server licence,
and WinCC client install option to connect to WinCC server.
No need project in WinCC client.
When WinCC client connect to WinCC server, every thing on client same as server.
You can limit function on client by user logon.
I tested this function for 3 years ago, it work OK .
sorry for my English
BR
BR
