HELLO,EVERYONE !
Now , I am using a wincc ,connect with two s7-300 plcs . I know the addresses are different .
But, I have never do the work before .
Should I use the STEP software to set one PLC address , then I set the other one's address ?
Is there any person help me ?
Thanks !
[?+]: S7-300 MPI ADDRESS
poovai12345
Re: HELP------S7-300 MPI ADDRESS
Hello ,
for connecting two S7300 PLCs you have use CP5611 Card in The PC and make a Network using a Profibus connectorand Cable. In WINCC you have to Add two Connection (Station ) give differnt MPI address.
Regrads
Poovai12345
Regrads
Poovai12345
jet jiang
thank you very much!
